- 27 Jun 2008
motherboard 12v or 2x4 help needed Urgent Help
Onsite with this build can anyone advise please
Hello I have a gigabyte ga-ep45-ds3r/ds3 motherboard and it has an 8 pin atx_12v_2x4 socket. the manual says that if the mobo has an 8 pin socket use the 8 block connector. The manual goes on to say if the mobo has only a 4 pin socket just unclip half of the block. Last time I plugged the whole 8 block into the mobo it burn't out. This may have been caused by me not using those spacers to keep the mobo of the inside of the case. My question is should the system run with just the 4 pin in or am I supposed to use all 8 pins?
Using a E8400 dual core cpu
