Can I use my N95 8GB like a USB Stick?
5 Jul 2006
Is it possible to use the N95 8GB like a USB Stick? Or are there any software issues? I need to take some word documents into college and i don't have a USB stick.
Should be able to, i can o my 5310 express music, just connect it ith the usb cable and select data transfer mode on the phone and it shows up as a drive in windows, you dont need pc suite either to do that
Or if you have a card reader, just take the card out of the phone, pop it in the reader, transfer the file across, and then do the same at the other end.
Can do but with the 8Gb model is the memory fixed and i dont think it has an expansion slot
yea u can, just use the usb cable and when u plug the phone in click data transfer on the phone and then it should come up on the pc in the notification area at N95 8GB, and then another one saying mass storage device :) bish bash bosh :)
