Gigabit Network : Broom!
18 Oct 2002
Cambridge, UK
Bought a couple of Intel PRO/1000 PT Desktop Adapter
Blimey :)
HEADRAT
Wooohhaaa..
I take it thats a PCI-E adaptor? :eek:
Has the TCP/IP window size been changed?
Also has the ICS service been disabled?
Thanks
Andy
I need to get around to tweaking mine, oddly at 1st attempt Solaris wouldnt let me change the MTU on my pro1000 :( The other is in an ESXi box which looks easy to change. Might get one for my Desktop rather than the onboard NIC, but its splitting hairs really - not exactly slow at the moment :D (~50-60mb/s)
If its XP try this.
Lan Card Properties
Untick QoS Packet Scheduler
Services to Disable – Start > Run > Services.msc
Windows Firewall/Internet Connection Sharing (ICS)
Registry Changes
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
Add a DWORD named TcpWindowSize
Add the value 131400 (make sure you click on 'decimal')
Add a DWORD named Tcp1323Opts
Add the value 3
Andy
That's damn nice. I almost bought some of these cards a while back but didn't get round to it...
...I'm quite tempted again now :)
I turned off autotuning and now I'm getting 100% utilisation :eek:
netsh int tcp set global autotuninglevel=disable
What network switch do you have? As thats impressive throughput for the switch as well as the network cards. Also you using Cat5e or Cat6???
damn nice :cool:
how much for the pair?
what was the speed before?
I've seen pairs of these go on an auction site for less than £20.. Think it was about £15. It took a fair bit of me stalking the listings for a few weeks to see them go that cheap though...
Nothing fancy switch wise NETGEAR GS105 ProSafe, using CAT5e, very short cables though ;)
You on Vista Sp1 there too?
Yup, one machine is Vista X64 (SP1), the other is Windows Home Server
with a bit of storage ;)
