3000:1 contrast ratio
18 Dec 2007
Hi i went in a computer shop near me and they had an AOP 22" monitor. i've checked their website and it says that its got a 3000:1 contrast ratio. i was intending on getting the Samsung SM-2253LW Aqua 21.6" which has a 8000:1 contrast ratio. i'm guessing higher numbers = better but could somebody explain this contrast ratio malarky to me and explain why the samsung is probably a better buy. thanks
Samsung use dynamic which throws the number out of the window. Dynamic is vile. I have a Samsung PC monitor I don't use dynamic preset either (and have owned Samsung LCD TV and Plasma again not used dynamic)
No, higher contrast ratio isn't better, it's a ruse to fool you. These "x000:1" contrast ratios are nothing short of dishonest as they are achieved through "dynamic contrast ratio" which is where they change the brightness of the backlight on the whole screen. Net effect is that it looks rubbish and you'll be turning it off.
Just because a spec sheet has a bigger/better number doesn't mean the monitor is any good, normally the exact opposite.
About the best you'll ever get from an LCD in reality is about 1000:1 (static that is), maybe 1200:1. They just let too much light through to do any better. Dynamic contrast means the black and white measurements were taken at different times with different screen content, so when they measure black, the screen detects a black screen and dims the backlight to minimum. So it's a bit of a con. It does get you a better black depth, but they have to amplify the signal to then get the rest of the picture bright enough when the backlight is dimmed, and this leads to some nasty problems.
We have dynamic contrast on our Samsung LCDTV and had to turn it off - it was bringing out all kinds of horrible hues on compressed media. It completely ruined the Moria sequence in LOTR. Honestly it's worse than having poor black depth.
The big numbers sell more screens though.
Also it makes brightness pump up and down:
That game does some effect like dark edges but that monitor uses dynamic fraud and end results is fully fitting to brightness being pumped up and down:
what do people i think i should go for then. a £149 22" AOP monitor or the Samsung SM-2253LW Aqua 21.6". i would go on their website and find all its specs but for some reason i can't find the website anymore, nor is it in my history.
There are higher contrast panels like the Samsung LTI460A-A03 which has CR of 2000:1, but they are expensive and normally only used for digital signage.
i have terrible backlight bleed around the edges of my samsung 2232BW, this is "common" in the samsung range supposedly. apart from that its a decent monitor.
i've been saying aop all this time. silly me its aoc. here are its specs if anyone can give me any info about how good it is cause i dont know
22" 2216Sa
OVERVIEW:
The AOC 2216Sa offers premium picture quality for graphics-intensive applications. It comes with 3000:1 (DCR) contrast ratio, which delivers exceptional image clarity, and 170-degree viewing angle to provide increased visibility from side viewpoints. It's response time is 5ms, a key feature that prevents fast moving objects from becoming blurred.
The AOC 2216Sa offer consumers brilliant large screen performance at highly competitive price.
RECOMMENDED FOR:
Architecture, Design, Corporate Environments
PRODUCT DETAILS:
* Analog inputs
* 1680x1050 maximum resolution
* Special features: DCB-Dynamic, Color Boost, Contrast Ratio 3000:1 (DCR)
* 300 cd/m² (typ)
* Typ. Response Time (tr+tf): 5ms
good monitor?
Whole shipload of BS!
If TN were CRT it would have been taken from end of production line straight to waste dump because of having been considered faulty.
This is what kind viewing angle/image quality TN has: From down angle colours "black out", from up angle black turns grey. So you either got darker upper edge or lower edge without black.
http://www.behardware.com/articles/686-8/review-of-the-dell-2407wfp-hc.html
Sure makes great picture quality!
"Advertising is legalized lying."
-H. G. Wells
And not even any digital input connector!
Yes, good Post-it holder, paperweight or maybe even display if you don't want/need any kind (colour) accuracy.
i think i will be actually going for the 'Samsung SM-2253LW Aqua 21.6" Widescreen LCD Monitor - Glossy Black' . with 8 more posts i will be getting free shipping which makes it the same price. and i dont mind losing .4 of an inch. its got good reviews compared to the harsh review from esaT.
ohhh but for an extra few pounds i get the Samsung SM-2253BW Aqua 22" Widescreen LCD Monitor - Glossy Black. ok so new question
or
i think i know the answer.. 22" but any opinions on these two monitors are welcome
meh. i just bought the Samsung SM-2253BW Aqua 22" i'm sure it will be super
