New Card - Testing it?
7 Feb 2004
I have a new card but want to test it to see if its ok.
I have played a few games but what is the best thing to test on to make sure its ok?
Benchmark?
If so which one?
THanks
Run a stability test which lasted 4000 secs. Seemed ok for furmark.
Does it end as it just seemed to carry on going.
Just about to run a bench with it.
Did run hot ay 91degrees though, ouch!
Furmark v1.4
Full Screen
Score 1613 o3marks
PFS Min: 23
FPS Max: 36
FPS Avg: 27
Time 60000ms
Res 1680x1050 MSAA 4X
Renderer: Geforce 9800 GX2/PCI/SSE2
Active GPUs: 2
Drivers Forceware 6.14.11.7519
CPU [email protected]
CPU Speed: 3200Mhz
OS XP Service pack 2
Does that look bad or ok?
I get :-
Furmark v1.4
Full Screen
Score 4700 o3marks
PFS Min: 67
FPS Max: 104
FPS Avg: 78
Time 60000ms
Renderer: GeForce GTX280/PCI/SSE2
Active GPUs: 1
Drivers Forceware 6.14.11.7741
CPU Speed: 3501Mhz
Something definitely up there.
Furmark v1.4
Full Screen
Score 1613 o3marks
PFS Min: 23
FPS Max: 36
FPS Avg: 27
Time 60000ms
Active GPUs: 2
CPU Speed: 3200Mhz
Furmark only uses 1 gpu on sli or crossfire from what i have heard so it maybe right when comparing it to a gtx280
Still for 1 gpu it looks pretty low don't have much experience of furmark.
Are there any other benchmarkers that I can use that would work with sli then?
I played GRID with all the shinys turned up, so I think the card is working ok.
I have increased the fan speed now and it heats up to about 71 on max, so that is a lot better than the 91 i was getting.
Can't remember details, but ran 3DMark 06 and I used to get about 19k, and 9.5k in Vantage. Those were at the default settings. Your card seems fine to me.
I run the crysis benchmark and got
Min FPS: 15.76 at frame 148, Max FPS: 67.01 at frame 118
Average Tri/Sec: -44107372, Tri/Frame: -947461
Recorded/Played Tris ratio: -0.97
TimeDemo Play Ended, (2 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
06/09/2008 15:33:48 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 46.55
I would assume that is ok?
And got this running at 1680x1050
Min FPS: 20.83 at frame 139, Max FPS: 52.03 at frame 131
Average Tri/Sec: -29088746, Tri/Frame: -752099
Recorded/Played Tris ratio: -1.22
Completed All Tests
06/09/2008 15:38:35 - XP
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 38.68
Play Time: 57.68s, Average FPS: 34.67
Min FPS: 21.94 at frame 138, Max FPS: 52.23 at frame 915
Average Tri/Sec: -26102282, Tri/Frame: -752806
!TimeDemo Run 1 Finished.
Play Time: 49.24s, Average FPS: 40.61
Min FPS: 21.94 at frame 138, Max FPS: 54.66 at frame 95
Average Tri/Sec: -30504584, Tri/Frame: -751098
!TimeDemo Run 2 Finished.
Play Time: 49.06s, Average FPS: 40.77
Min FPS: 21.94 at frame 138, Max FPS: 54.91 at frame 110
Average Tri/Sec: -30596738, Tri/Frame: -750470
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
07/09/2008 16:31:44 - XP
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 40.69
