Perhaps mavity?
Your engine turns over a lot easier in 1st gear which is why people always put it in 4th or higher when parking.
EDIT: damn beaten to it.![]()
Maybe the weight of the car is overcoming the resistance produced by the engine when it is in first gear. Try sticking it into 4th gear, thats what I do.
You sure about that? Pushing a car in first gear is relatively easy whereas if it is in 2nd or 3rd it seems to be harder. At least that's how it seemed when I was helping to bump start a mates car a couple of years ago.
Why were you pushing it in gear anyway?You sure about that? Pushing a car in first gear is relatively easy whereas if it is in 2nd or 3rd it seems to be harder. At least that's how it seemed when I was helping to bump start a mates car a couple of years ago.
But yes, you should park in 1st (or reverse obviously).Test it out. At 25mph in 1st, turn the ignition off. Then do it at 25mph in 5th. The car will slow dramatically in 1st compared to 5th.
No, other way around, the engine is much easier to turn over in higher gears. In 1st the engine should hold on a mild slope. If it's a steep slope then the car will creep forward as compression leaks out of the cylinders, especially with a well worn engine.
Everyone here seems to have entirely missed the point that I think the OP was trying to make, that the car rolls BACKWARDS. Certainly my idea of mechanics suggest that the car should not be able to do that. I don't what would be causing it though.
All slopes are uphill one wayIt's parked on an uphill slope?
But from what he's said it's rolling backwards down a hill.All slopes are uphill one wayBut from what he's said it's rolling backwards down a hill.
