um, obviously![]()
Well then it'll need more power than a 360 or PS3 to run it.
um, obviously![]()
Well then it'll need more power than a 360 or PS3 to run it.![]()
Yeah and a quad core and 8800GTX is quite significantly more than the consoles.
I dont think people should be going around saying oh an 8800GTX will be more than enough!!
Remember crysis, the same could well happen here, I wont believe it will be running perfectly on an 8800GTX untill we've had first hand reports on that.
No one ever said Crysis would run maxed out at 1900x1200, go back to your cave troll.
I'm sorry... I thought you called me a troll then...
I seen plenty of people thinking it would be running on high perfectly fine with there old 8800GTS's
There's a big difference between people thinking and actual using their brains to think and read.
People reading is why they got the idea, crytek themselves even made out you could be running it perfectly with a GTS640.
It ran perfectly on my 8800GTS 640MB on all high.
At 1680x1050?
What frame rate? I guess is below 30fps if fine for people and dropping into the teens then so be it, but by playing fine I expect 40+.
Havok PhysX as well, can't wait.![]()
does that mean one needs a physics card?
AMD cards do Havok Physix on the gfx card![]()
