- 31 Oct 2005
- South-West
... Has made me lose all my resolution settings?
Got the g/f a new tv and with it ordered a vga cable for using the pc on the tv from time to time. Ended up putting the pc nearer the TV than the pc monitor so used the blue vga cable that came with the monitor for the TV and the new VGA cable on the monitor.
Found that the correct res for the TV was found straight away and was very impressed that it did it so quick.
When I went to use the pc I found that the res had set itself to 1024x800 (default is 1400x900) and that the 1400x900 was no longer there.
After playing around a bit I swapped the oringal cable from the TV back into the monitor and found then that the monitor worked perfect and that the tv res couldn't be set to it's native settings...
This then led me to belive that the cable isn't picking up what the res should be and is stopping me from picking the correct native res... why the hell is that?
Any help please post as I am stumped on this one... how does a vga cable (that looks identical to the other vga cable) stop me from having the native res & give me a bunch of random ones!?
Cheers,
Doug.
Cheers,
Doug.
