Thought you would have known that being a 360 fanboy.
I'm pretty sure time has an effect, considering it's heat warping the motherboard is it not?
So, the more it's on, the more it will be affected.
With 3RROD the X-clamp cant retain enough pressure to keep the GPU connected to the motherboard so the solider joints break. Pressue is lost as there is actually a gap between the motherboard and the case + the metal is of such thin/low quality that there is space in which the GPU can be disconnected through heat warping.
The issue comes from the X-Clamp not maintaining a constant even pressure across the chip when heat cycling, not that there isn't proper contact between the GPU and heatsink.
I've had about 6 Xbox 360s and not had 1 RROD, am i the only person?!
Its nothing short of media hype, MS are in for the long run, ok they have had a massive loss with the 360 but the games they are pumping out is superb, there is no way the next MS console can be as bad as the launch of the xbox was and the hardware failure as the 360, third time lucky
You have to spend money to make money, its no different than Sony Corp being in massive debt but nobody brings that up when they go on about the PS3, let the games do the talking....simple as.
yes they doits quite a major talking point. everybody knows that the ps3's are expensive to prroduce and sony are still making a loss.
lets not turn this in to another console war though?
Why the hell do you need 6 xboxs?![]()
Thought about reading the thread?
