The thing with Alfa Workshop (who are probably one of the best Alfa indies out there in terms of knowledge vs efficiency vs cost) is that their prices aren't typical of indies. They're significantly cheaper, so unless you live around Royston, you might as well add another 20%-30% to whatever it is they're charging.
You go to an indie that appears to offer a comparable price and you run the risk of them not changing something that should be changed or using non-manufacturer parts with the result that you go away thinking its cheap but the costs stack up later on or even worse you're left with a car that's a ticking time bomb. I remember going to a place for my sister's car and I enquired as to what they did when changing the cambelt at the 72k interval. They quoted a list of parts but which didn't include the variator or water pump. When I asked them why they didn't propose replacing those parts, they said they only replaced them if the customer specifically asked. That's absolute madness.
