tagan 530w just went bang!
11 Jan 2006
Iv had a tagan easycon 530w for 2 and a half years and it just went bang! My system was probably drawing less than 300w all the time as well,
Lucky their warranty is 36 months ;). Going to RMA it. Will the replacment have a brand knew 36 month warranty?
Warranties are from the original time of purchase, so you will not get another 36 months, just continue from when you bought the first.
- Pea0n
- Pea0n
Most companies will extend the warranty by 90 days from when you recieve the goods back - so if you're less than 3 months from the end of the warranty period you'll probably get a few days extra.
Hi
Out of interest did it take out any components, only asking coz i'm running a tagan 480w that is about the same age.
Nope everything was fine, as soon as the knew psu went in it all booted up again. Maybe i was just lucky.
Just out of interest what is the purpose of the manually switch-able split or combine 12v rails on these psu's and when is it correct to use each setting? I mean mines was always on split and I was wandering if that cause it to fail?
no that wont caus the bang. and a good psu is one that goes bang but only takes it self out.
well doen tagan.
on the other hand.....i had a Qtec, and £1000 worth of shiney new items....
