If you're only just getting 1080p down your long runs you may struggle to get 2160p in the future, should you choose to go that way. The band width requirement for 2160p is double that of 1080p. .
The down side to that is that you may not be future proofed. If you're only just getting 1080p down your long runs you may struggle to get 2160p in the future
Just bought a 7.5m HDMI 1.3 cable for £15, arrives in a few days so we'll see how it is. Note: I expect it to be fine![]()
I picked up a couple of cheap gold connection 2 meter ones from ebay. Paid less that £10 in total and they're very good quality.
You don't need to worry about cables putting weight on your HDMI socket unless you're doing something stupid like hanging weights off of it.
I had a cheap cable that had poor connectors on that got bent to one side by the cable when I moved the furniture. It damaged the socket in the back of my £700 amp which cost me £150 to have repaired.
Had the connector been of a decent quality and had sat flush in the socket it wouldn't of happened and I've seen cables being sold since with the same connector on for all sorts of prices. I've since bought another cable at the same price that's miles better in quality.
I'm not advocating stupidly priced cables just trying to help other people avoid the same problems........thanks for the sarcasm anyway.![]()
i doubt that, if you hit the connector with enough force to bend it, a stronger connected would have done more damage to the socket i would have thought.
