- 18 Oct 2002
This is not a medical advice thread.
I had an MRI in December 2007 because I am suffering from hearing loss in my left ear.
I also happen to work in the microscopy and imaging field and knew that if I could get hold of the data, I could examine it myself and render it in our software.
I've just managed to get hold of the raw data and thought I would let others know, if they are interested in seeing theirs for themselves:
I spoke with the doctor who referred me and explained that I knew I had a right to see any medical data about me, including images and scans. He agreed but cautioned that it might be difficult to get hold of the raw data from the scan because of the proprietary image formats used and some copyright issues due to the manufacturers of the MRI machines. (I don't know if this is true or was just a brush-off).
Anyway, a few months later I received a letter from the medico-legal department of the hospital with a form to request the data and to send a £20 admin fee. They mentioned photocopies and that is what I expected to receive. I was really pleased when a CD showed up in the post.
As I expected, the images are in DICOM format, but the CD had a viewer on so that may be all you need. In order to render the scans in the software we use at work, I needed to export them as TIFF, or some other standard format.
For that I used IrfanView with a DICOM plugin (the formats plugin on the plugins section of that site). I needed to rename the images with a .dcm extension for IrfanView to open them.
I then converted them to TIFF (you could use JPG or BMP, whatever) and imported them into our sofware for rendering them.
As for open-source renderers, you could try Osirix (Mac-only, also a DICOM viewer) or try BioImageXD (Windows).
Perhaps what was most interesting of all, is that a file on the CD holds the diagnosis information and I found out a lot more than the doctor told me
I hope this proves useful to others.
EDIT - TTIUWP!
Here's a low-res (the actual images are 512 x 512 each) image showing each slice they took of my head:
EDIT 2 - Uploaded a couple of very small (256k each) movies of the renders:
IAMs (Internal Auditory Meatus)
Whole Head
EDIT - TTIUWP!
Whole Head
