Ok here is my review for the Hyundai W240D. Firstly, just to say I am not a monitor expert and only have my old monitor and my flat mates monitor to compare it to.
The outside
Very nice style and design, the glossy surface does seem to be pretty easily scratched, not a major point but just be careful. The base has a large footprint, so while the monitor is only about 11cm deep, the base (ie the deepest part of the unit) is 24cm deep. The stand is easy to use and offers a decent amount of flexibility with adjustable height and it can turn 90° on its side. Great number of inputs, DVI, HDMI, VGA, and Component. It comes with DVI and VGA cables, so you will need to buy the extra ones if you want them. I haven't tested the speakers, after all they are monitor speakers, does anyone even use them?
Front controls are very hard to see without bright lighting but that isn't really a problem as you shouldn't really need to be going into the OSD very often. You can cycle through the inputs but just pressing the down button without having to go into the OSD. Unfortunately whilst the 'Soft touch' seems like a funky idea, it is rather hit and miss. For me the menu and select buttons can take 10 presses before it responds but the up, down, plus and minus work virtually every time. Highly annoying when trying to change settings in the OSD, but as I said before you should only really be needing to do this once then you are done.
The inside
It has a Samsung S-PVA panel inside and so of course you get great viewing angles and good colours. Unfortunately this is where the good news stops. I am slightly confused as to this next part as well. With RTC (overdrive) turned on there is very bad ghosting. When turned off, there is much less ghosting but you can still see it when moving a contrasting colour over another, eg black Winamp skin on white background or vice versa. I compare this to my 19" Xerox XA7 (TN panel) and a Gateway 22" with PVA panel both around 2 years old, and neither have any problems with ghosting.
On a more positive note I can't see any blacklight bleed I took a picture of it with a blank screen saver not really sure if the picture is of any use but here you go.
I don't have a a Xbox/PS3 to hookup to the monitor to test it on with them. There are 3 options in the OSD for resolution matching.
1 to 1 - This is what most people want as it uses the exact number of pixels that are asked for. If I put a 1280x1024 resolution on my PC with this I get the square picture in the centre of the screen without stretching or distortion.
Aspect ration - This will keep the same aspect ration as the requested resolution but will use as much of the screen as possible. If I asked for the 1280x1024 again it will again be in the centre of the screen but it will use all the height available.
Full(16:10) - This will stretch the image over the entire screen.
Ok I dont think I explained that very well so here is a picture to help.
In conclusion
If you are really looking for a monitor with great viewing angles and response time/ghosting isn't a big issue for you then sure go for this monitor.
Personally, I slightly regret buying it. I got sucked in by the marketing. The multiple inputs and adjustable stand are great, but I don't need it. As a gamer I should have at least seen a 24" monitor with a TN panel in action before I made my decision. Overall its not a bad monitor but my advice would be to try and see ANY monitor in action before you buy it.
NB Make sure you have a ATX (Kettle) cable as OCUK failed to supply one for me.
