Patriot Memory for Asus P5Q3
7 Sep 2008
Hi,
Can someone tell me if this memory :
Patriot Extreme Performance 4GB DDR3 DUAL KIT 1333MHZ LOW LATENCY 7.7.7.20 DUAL CHANNEL
will give me a post and work on the Asus P5Q3?
How can I work out if any memory will work without actually buying, it is there a website for this?
You'll have to remove the link as it is a competitor and against the forum rules.
Have you checked the memory list on the ASUS website for compatability?
thanks for that
It looks like on first impulse the memory I was referring to isn't in that list.
I see one Patriot PDC32G but the one I was looking at is PDC34G. Anyone ever rang Asus before?
Oh one last question if the memory I was looking at is NOT on the QVL does that mean it will definately NOT work?
I wonder how QVL works and if they only test certain brands,
