Yes there is a .cab you can install to get rid of that sms style, google nonthreaded sms or add me to msn and ill send it you.
There should be one , they all come with one I thought?
Its a handsfree where with a 3.5mm jack so you can also use your own headphones
Anyone using TomTom on this? If So what version?
Has anyone had any more thoughts about this? I had another 1hr connection going today when I got back to my phone and it still tries to connect every time I switch onHey guys,
Since setting up email on phone, my Omnia tries to connect to the internet at regular intervals? I checked it last night to find that I had been connected for over an hour without knowing... This morning, when I switched it on it immediately tried to connect?
I've turned of 3G manually and I've set my phone to only receive my mail manually, which I assume requires me to manually connect to the internet
Any ideas?
Cheers,
SW.
Seems to have only started when I started using email on my Omnia
SW.
2 weeks now till i might get my replacement![]()
why 2 weekds ? who is the contract with ?
its on o2.I've now wasted a fortune on 3 martin fields screen protectors. What a load of rubbish.
There are no tabs to hold the protectors so it's nigh on impossible to not touch the edges of the protector. Then the edges of the protector shed particles that get trapped under the protector. Then the whole thing is cut slightly wrong so it doesn't quite match the shape of the screen and makes it look like you've just put sticky back plastic over the phone.
A waste of time and money.
