- 21 Jul 2004
- Harrow, UK
I am thinking of attaching my power block to the back of my desk... how would I go about it? Can I get some brackets or something? If so, where could I get such brackets?
I had hoped it had those... but it doesn't![]()
Good descriptions of your movements InvG!
you want some of that metal strip stuff with the holes in you could bend it round the block and fix it to the desk with som self tappers.
cable ties for the win
How would that work?
It wouldn't.
Although I suppose he could put screws in the wall, put cable ties on that, then put cable ties round the power adapter, and then link the two sets of cable ties and make one huge mess that doesn't work properly.
InvG
ScrewFix, fixing Band
http://www.screwfix.com/prods/38619...feed-_-Building-_-Builders Band 10M&source=aw
may be able to get it at auction cheaper.
It wouldn't.InvG
