Arctic Freezer/ Freezer Extreme?
6 Sep 2008
Near Hull
Wah, didn't know this thing existed. Is it any good though? I'm looking to change my Freezer 7 Pro. Looks bloody massive.
i don't know how good it is, i saw it on a diefferent site i was looking for a good cooler for mine, so posted the link to the companies site instead of a competitors site as OverClockers don't seem to have it.
but it does look good.
anyone has http://www.arctic-cooling.com/cpu2.php?idx=162&disc= or similar, are they good coolers??
Its been on the cards for over 1 year and keep getting put back for some reason, its now put back again and will be hopefully end of this month (I think its Sep or Oct). :confused:
The freezer extreme is supposed to be the better of the two.
I read somewhere that it is supposed to compete with the tuniq tower, as well it kinda of looks like it and kinda same spec.
But like the arctic freezer 7 it is meant to be a decent budget cooler.
I've just read that the Arctic Cooling Freezer 64 Pro PWM is only good with CPU's upto the AMD Athlon 64 X2 - up to 5000+, But i'm using the AMD Athlon 6400+, so i guess i'm going to need something better than that one. hopefully the xtreme will be here soon and good enough.
Yip that cooler is too small, I used the Freezer64 on a AMD 6000+ at launch and it ran hotter than I would like at idle which meant the 90mm fan had to run 100% all the time and they are a bit noisy.
You want 120mm cooling today IMO esp if you OC.
so the freezer xtreme would be a good cooler for it then?
Main Features:
• Unmatched cooling performance – 160 Watts
• Unique twin tower 102-fin heat sink design
• Effective heat dissipation via 4 double-sided heatpipes
• 1 ultra quiet 120mm PWM fan******
• Patented fan holder eliminates the buzzing sounds
• Voltage regulators and north bridge cooling
• Pre-applied MX-2
• 6 Years Warranty
For your hot CPU any good 120mm cooler like a True 120 / Tuniq or Noctua will do the job.
i think any non-stock cooler will be better than my current one is. i'm still using the stock cooler from my AMD athlon 3200+ single core.
so i think i will go with the freezer Xtreme when it finally arives in some online stores.
I would not use stock with a AMD6000+ or above, and after that 1 build for a customer with the Freezer64 it was only 120mm Coolers.
Now I use Intel anyhow as I don't like the Mobos for the AMD now after the 590I NF's.
