- 4 Jan 2004
- ¯\_(ツ)_/¯
Right, I'm planning on building another sub enclosure as I like the sound from horn subs, and commercial ones cost thousands.
Now, I have the option of building an absolutely massive box that will go down to 20Hz, or a much smaller one which will work well down to 30Hz.
This is the simulated response for the 30Hz enclosure with 100watts going in to the sub:
Now, as I'm not using this for HT, so is there any music with significant things going on below 30Hz?
I listen to all sorts of music, quite a lot of bass heavy stuff such as dubstep and some D&B, but a lot of this intended to club sound systems which often don't have much output below 40Hz unless you are at somewhere like Fabric.
So, I've pretty much decided on the 30Hz box, will I be missing much by having less SPL between 20-30Hz?
