i would have upgraded the GFX card rather than a new cpu for better FPS
+1
There are many people on this forum spending too much money on the CPU and not enough on the GPU (for gaming anyway).
e.g. £100 CPU + £200 gfx card >>> £200 CPU and £100 gfx card
If they both run at the same speed then no for COD4. The game is Gfx Card intensive as are all FPS, the Res you run at will also have an effect as will the amount of AA/AF.
Thats wrong bud, i noticed a hoooooge frame rate loss when i went dfrom a quad @ 3.0ghz to a e8500 @ 4ghz . The quad is enabled for cod 4 and cod 4 is coded yto use 4 cores
Doesnt COD4 use the quake engine which is multithreaded?
i donno what you was using but this explains quads is useless for cod4
http://www.guru3d.com/article/cpu-scaling-in-games-with-quad-core-processors/3
I dont think you would get much difference frame rates iw ould just overclock your e6600.
I wouldnt buy anything until really you need to use all the cores.
well that reviews noty the best lets be honest, it shows all cpus doing the same fps, thats bull, and i was talking about oced chips not stock. Do your research![]()
