usb pen drive benchmark
Permabanned
17 Nov 2007
Chester/ Bristol uni
Is there a programme where you can see what read/ write speeds you can get out of a USB pen drive.
My 8gb corsair flash voyager, and want to see how quick it is.
cheers guys
HD Tune Works, and lucky for you i have got a 8GB Corsair Flash Voyager! :D
mines the normal one, just in case youve got the GT version
http://img524.imageshack.us/img524/1808/8gbaa5.jpg[/G][/QUOTE]
nice one =]
I've the normal I assume, the £20 one off OcUK.
How do I get HD tune to bench my drive? It'll only do my normal HDD, I don't need premium do i? =\
it should be on the menu, when you click on the hard drive name thingy, if its plugged in, if not then i have no idea.
is there a premium HD tune???
Nice speeds! I get an average of 28-29 with an older PNY 8GB model.
ive tried my other 4GB corsair and the speeds are exact.
but on the topic of flash usb, i would only recommend the Corsair survivor model, the casing is strong and comes with those army style chains, that thing is completely water proof and really strong, can have a car run it over with no problems :D with the voyager, the plastic end bit gets worn after a few months and looks like it will eventually break off and you will have to carry it without the neck band thingy... and the lid gets loose and will fall of by itself :(
it didn't pick it up before because the drive was plugged in after i opened the software ;)
it was just showing an average of 22 =\ it might be because it's on the front of the case rather than a port at the back... but there isn't a port at the back that's free to check =\
