Grenadine
18 Oct 2002
Rocks.
If you want the cherriest coke you've ever tasted try Grenadine and coke. It's amazing.
Any other grenadine fans?
A side question - why do supermarkets insist you are over 18 to buy it? It contains no alcohol..............? Is it the same for all mixers?
Love it, a fundamental component for cocktail making. Supermarkets definitely shouldn't be asking for ID when you buy it though. It's probably because it appears like an alcoholic drink and is found with all the spirits etc.
You can get grenadine with alcohol in, suppose some shops cant be bothered to check and just say you have to be 18
