Again, if you change any graphical settings, quit out the game and reload it and that seems to make it very stable for me anyway.
Ahhh, this could explain things, i changed the settings then went straight into the game, lets have another try...
its definitely harsh to compare a default game with a game you've probably been tweaking for almost a year now and have some ridiculously long autoexec file for
not got any issues with it at all myself well apart from needing a new card for high res, plays a lot smoother than the original absolutely zero stutters from first load to when i finish playing
been playing a bit of wars online, that also plays way smoother with no stuttering ,settings have different names good visuals = gamer, best visuals = enthusiast, been playing it on all good visuals with mini autoexec and getting 35-70fps averaging 50. tdm with vehicles seems a lot fun and the tdm in general seems good, definitely better than the originals multiplayer although still not something you could/will play everyday though
try this very simple tweak, make a file called autoexec.cfg in main crysis warhead dir and copy this into it
con_restricted = 0
r_useedgeaa = 2
r_texturestreaming = 0
con_restricted = 0
r_useedgeaa = 2
Just tried to flank a APC by jumping up onto a rock using strength mode. I then proceeded to fall THROUGH the top of said rock and became trapped inside with the APC still shooting at me but hitting the outside of this apparently hollow, see through rock, i tried to get a screenshot but print screen didn't work... looks like crytek are up to their same old buggy tricks![]()
Well what I fully expected the optimizations to be were custom configs that are essentially reduced versions of crysis' high/very high, with effects lowered that your average gamer wouldn't notice/miss.
Reviews seemed to have implied the enthusiast setting runs great compared crysis' very "high setting".
Anyone playing on enthusiast? Is it playable?
