The "my pc aint that great , will it be any good to run crysis warhead?" thread
1 Sep 2007
Hi guys :D
Sorry, about the millionth thread on crysis warhead - but I thought this would help most people with non-behemoth pcs.
Here is my spec :
e6420 cpu 2.13ghz
2gb ram
7900gto 512mb
So as you can see, my pc is decent, but not great. Im currently installing it now, so after a few plays through ill report back here with my results :)
I can't run my rig any higher than Mainstream unless I use DX9 then I can run GAMER settings I think another 2Gb of ram would fix this as the game uses 1.7Gb of ram currently good job I ordered some today
What about my little laptop with its nVidia 8600M GT card? 256MB of DDR2 mem. Will it run nicely at 1280x800 dost thou think?
no. That ram is tiny. Upgrade it then yes on low
Ross, I have a sneaky suspicion that ic1male means that the 8600M GT he mentions has 256Mb of DDR2, rather than the actual memory installed on his laptop. :cool:
I have an 8600GT in my Dell XPS 1530 with DDR3, so I'm hoping it runs Warhead ok. It certainly ran COD4 and Black Site : Area 51 ok, which was an absolute system hog on a lot of PC's.
Use Dx9, I run it on Enthusiast at 1920x1200 on my 8800GT.
How much RAM do you have Margaret? I'm running it OK on Gamer at 1400x900 with a 3870 (which should give me similar performance to your GT), but I'm not sure it could hack enthusiast...only got 2GB RAM though, so I reckon this may be the issue.
Well the original game ran pretty badly on my 8600M GT...settings on medium/low....this might allow you to take things a little higher cos the engine's optimised.
4 :)
Enthusiast should be fine on a 4850 especially at that res!
Edit: Oops not sure where I got 4850 from!
one more :)
amd x2 5000+ 3.1ghz
4gb geil ddr2
nvidia 8800gt can i run it on 1280x1024?
manic111 3870 is slower than 8800gt ;)
good ;) thanks! is it better to order it on steam? or buy it from shops?
Found it easier from the shops personally, couldn't be bothered to wait for mine to DL (and I have a bandwidth limit) but I guess it depends on your ISP as to what you go for!
