So, is there any way of being able to permanently set this, or do you have to right click each time you want to play?FIXED IT : Its because you're using the Classic Start Menu , change that to Start Menu ( original )... The games option will be there![]()
Also, is there any way of being able to play in dx9 with the Classic Windows interface selected?
Cheers,
SW.
Nice. Thanks budJust drag the Games folder from the start menu onto your desktop then switch to the classic interface... Its how i did it![]()
Must admit quite amazed this game is perfectly playable maxed out at 1920x1200 on a £65 odd 8800GT.
The website it links is also usless, as you'd expect from EA
is the date on your computer correct?
It looks good but I swear the first game looks better
Right click it and go to properties then set launch options add "-dx9"
where? properties in steam or what
Yeah, right.
Works great in Dx9.
