P35C-DS3R 1.1 F11 Bios?
1 Jul 2007
Various
Is anybody using the F11 BIOS for the P35C-DS3R? I'm looking at getting myself a nice new 45nm CPU, and if so would need to flash to these BIOS; I was planning on doing so before buying the CPU to make sure that it all worked OK. Has anybody got this BIOS, and if so is it all working fine? I'm currently on whatever BIOS came with my board (think it's F4...)
I have DS3P. F11 working fine here. If you have any problems once you have flashed the BIOS, just reset the CMOS. Not that I have had to.
Mine is the revision 2 of that board and I flashed it to rev 11 just for the E0 support, as I hope the get that revision of the E8400 soon.
I have not noted any difference between the rev 11 and BIOS and whatever I was on before, I think I was on F8 as I flashed it once before to give me the correct support for my 1GB drive.
In other words the BIOS and board are fine.
It is recommended that you clear the settings after. IIRC, and I might get the keys mixed up here, but when you are in the main BIOS screen press F12 (or is it F11) to save all of your settings as a profile. Then flash your board (fingers crossed) then load those settings back after you clear the CMOS by pressing F11 (or is it F12).
