removing thermal compound from cpu - nail polish remover?
5 Jan 2005
South East, UK
Hi - I used thermal compound (arctic silver 5) between my cpu fan and the cpu itself. I would like to remove this compound now. The fan has been on the CPU for a few years now and has seen daily use.
Can I use nail polish remover to remove the compound? If not does anyone know where I can buy Isopropyl Alcohol on the high street?
Cheers,
Dub
Think you can probably get isopropyl from any chemist-try Boots :) It's what I use and it works fantastically.
EDIT: Make sure you turn on the PC for a few minutes first to make sure that the compound is melted, otherwise you risk it sticking your CPU to your HSF which can result in damage!
Spray cans of IPA can be picked up from a popular high st electronics shop.
I used to buy liquid IPA and bottles of Acetone from Boots but these days they give you a funny look as these substances are popular with Drug Addicts and Terrorists! :o
Anyways Acetone is a bit OTT for cleaning away TIM, a Tin of IPA (pictured above) and a bottle of AKASA Citrus cleaning fluid is pretty much all that is needed to clean most PC gunk!
picked up a TIM cleaning set a while back has lasted a long time now and hardly used at all definatly worth just buying one will last a long time
It shouldnt really have any extra smell other than the smell of the chemical itself since that perfurme could leave a residue.
I use isopropyl alcohol 99% as well (IPA) as well. Dissolves the TIM easily. Evaporates very quickly leaving no residue.
