XP Logon in Vista?
20 Oct 2002
North West
In XP you can turn all of the fancy logon stuff offf so that you just get a square box in the middle of the screen.
Is there anyway to do that for vista?
very short answer this one. no. :p
there might be some 3rd party mod (i haven't checked) but there's no official way. even when you join vista to a domain, you still get the same welcome screen.
There are ways (using LogonXP / Logon Studio) to make the log-on screen in XP more aesthetically pleasing, but I found them to slow down the log-in procedure.
(It wasn't a huge difference, only like 3 seconds, but I often need to log-in quickly to check something)
Suppose there's no way to go back to the XP method whereby the pretty pics/usernames would appear without the administrator but then presssing CRTL-ALT-DEL would bring up the login dialog where you could logon as the administrator?
Have you got a screenshot or photo of what it looks like? I don't want to change all that and maybe be stuck with something I don't like :)
It looks like this..
Basically no image comes up, apart from the box for it :confused:. You have to type in your username too, essentially the same as the old style logon just a bit prettier.
Hope it helped ! :)
Also, any changes you make from that previous link you can put back so i wouldnt worry.
