Yeah tbh 3.1Gig has been the most I've seen out of the last 2 Q6600's
Buy second hand if one is available...
2 from around 1 month ago went to 3.6ghz...
but yea second hand is good idea because its cheaper, and prob good clocker
Back to the original topic with the CPUs; I've just had a quick look on the Intel Processor Spec finder and I must be interpreting the figures incorrectly. Both the 45nm and 65nm have a Thermal Design Power of 95W? I was trying to find some figures to see if there really was a huge difference but that was all I could find. Anyone got any figures that show the real world differences?
Since we're dealing with the same clock speeds as Intel's 65nm processors, power consumption has definitely gone down with the move to Penryn. Let's look at this thing at idle and under load running our WME9 test:
At idle, the QX9650 draws an impressive 34W less than the QX6850 - there's 45nm high-k + metal gate transistors in action for you.
Under load the power advantage is even more impressive, with a 47W delta the QX9650 under load uses only 11W more than its predecessor at idle. If you weren't dazzled by the performance improvements of Penryn, the reduction in power consumption is worth getting excited about.
