Video editing /merging two separate avi's together?
3 Aug 2003
UK
I have two separate avi files that I want to grab a part of the stream and place it on top of the other stream to get a picture in picture effect, can you recommend some software that will do this.. ??
Just to make it a little harder I don't want the whole stream / picture from the one file, but just one corner (it's already in PIP mode but the main image in that stream is the wrong one. Doh !
ELP :D
The main file is 655mb but I only need half of it ;) (starting at 5:34)
The PIP footage is 155mb and again starting approx 6 mins in (might need aligning slightly as one recorder takes a few seconds longer to boot up before recording)
Total footage time will be under 10 mins.
Something you can do rghjones?
I'm looking to make a picture within a picture, not just slice one image in between another, movie maker cannot do that.
Ah Sorry Mate didn't read the thread properly, Pinnacle Studio does this I know for sure but cant recommend any others as I only use Pinnacle Studio 12 Ultra.
PiP effects are easily done in the Serif range .ie Serif Movie Plus .I have versions 4 ,5 and just got the new X3 version , but not to keen on it at the minute .
I was thinking of selling my early versions , there very good and easy to use .
