hybrid is for matching same brand cards still, like using the amd 780g(i think its that) along with a normal gfx card and getting a little boost, it seems to work ok, but really isn't the best option around. ITs semi economical as the price increase from a non intergrated board, to one with intergrated gfx has been set very very aggressively, so you get like a £20 onboard gpu for £5-10extra. Really its only a good reason to do so if you aren't building a gaming rig and at a later date decide to buy a discrete gfx card, if you plan to game, just put the money towards a better card.
But the numbers aren't too great, its very very algorithm heavy and the reviews i've seen aren't great. 4870 cf + a 4850 was slower than the 4870cf'd alone, except in 3dmark where it was faster, and maybe one other game. Shockingly the more you vary the possibilities the more complex the calculations and balancing algorithms get.
Frankly 2x4850cf'd + a 4870 isn't remotely appealing at all, it creates more problems than it fixes and would be slower than the 4850's alone in lots of games, even if it were faster, selling both 4850's for £80 each or something and you've covered the cost of buying an extra 4870 for normal crossfire and much better, less complicated and less power hungry performance, that would need a less powerful gpu, less case cooling, less space and a cheaper motherboard.
