£100,000,000 on this firdays Euromillions?
Do you think there is a better chance with choosing your own numbers or lucky dip?
as i only ever do LD
Technically the chances are the same, but given there is no such thing as a random number when it's generated by a computer your LD will be slightly skewed in some way.
The only real difference, and it's a minute chance at that, is for 2 of the same lucky dips to be chosen, but then that is the same chance as actually winning, hehe
To say it again, I am more likely to die in the next 15 minutes that I am to win the lotto ;)
I'll bet Gilly et al at OCUk must be rubbing their hands together at the prospect of the orders they'd recieve if a member won the £100,000,000 on Friday.
However, if I won, I'd make damn sure I resigned from work the following Monday in spectacular style, such as an abusive message written by sky-writer aircraft.
LOL, you're going to get owned now!
Meh i got 4 lines £6
79,239,159.64 GBP
hmmm 2nd thoughts 100,000,000 sounds better :P
Craig321 said:
I'd buy such a stupidly expensive PC eventually as well, two of those £900 CPUs on an Intel Skulltrail etc :p
[DOD]Asprilla;12560609 said:
Live the dream.
I don't follow, what do you mean? o_O
I put eventually (I see you bolded it) as in that's not the first thing I'd do with 100M, there are better things to do :p
hmm, I'm 16, old enough to buy a ticket? I know I can get lottery ones, but does it apply to this too?
