Quick decision needed, Antec 900 or 1200?
6 Nov 2004
Hi, i'm buying either one of these here tomorrow with a Scythe Kaze-Master 5.25" Fan Controller - Black and was wondering what are your opinions?
For some reason I prefer the Antec 900 I know its the lower model but that case I think just looks nicer, however I do like the fact the 1200 has better cooling and black insides, convince me to buy the 1200 lol.
the 1200 has dust filters and a cable management area whilst the 900 doesn't =) the 1200 also has bigger fans as well as its increased size
Ive got a 900, wouldve got the 1200 but the price was a lot more than it is now. I'd recommend the 1200, the amount of dust my 900 had after 1 month was amazing, but its to be expected with a case with so many fans. Fitted some tights to filter the front fans now, easy fix but i expect it to be a pita to clean in a month or two.
The Antec 900 isn't too bad, just a bit cramped :)
That was my original plan, but I decided on the Lian Li A07 instead with a Scythe Kama bay at the front and I will git the 80mm exhaust fan at the top, worse airflow I know but it looks great if you ask me :)
Get the 1200. I'm glad i did. Loads of room inside and brilliant cooling too.
The dust filters do a great job and are easy to remove and clean.
Highly recommended.
