I was driving my mum's '99 BMW 318i along a dual carraigeway today when I began to smell burning. I thought it was coming from outside. About 30 seconds later the "low coolant" warning light came on. I kept a close eye on the temperature gauge until I could find somewhere safe to stop. After about another mile, the temperature gauge began to rise. I stuck the blower onto full hot but rather strangely it was blowing cold air
Anyway, the temp needle went into the red and the red light came on. I had to do another half mile whilst the temp gauge was at max in order to stop in a safe layby.
I stopped and turned the engine off. I opened the bonnet to find water everywhere and steam churning out of the radiator cap. I called a mate who brought out a drum of water. It took about 4 litres of water to fill the radiator again. This lasted for about 3 miles when steam began to churn out from the bonnet again. It wasn't until I stopped the car that water began to leak again.
From what I can see there are two possible causes:
1 - There is a leak in the coolant system and when the coolant runs out, the engine overheats.
2 - Something is causing the engine to overheat which is in turn boiling the coolant and causing it to overflow.
Can anyone make any suggestions? The car is sitting outside the house with a puddle underneath the passenger side front wheel.
Time for a new car methinks...
Thanks
Thanks
