I used autohotkey to play about with some shaman and trial accounts but i wouldn't use it as a permanent solution because it can be used to automate the characters so could potentially get you in trouble. Stick with keyclone or i think theres another one called octopus? which as far as i know is free but not as good.
As long as you are you are at the keyboard you are fine. Just dont automate anything. An example of something you shouldnt do is press 1 key and it does macro1 followed by macro2 after some time delay.
