Just placed an order and oh no
Status
Not open for further replies.
18 Sep 2008
I forgot to put case fans in the order :(
Antec Three Hundred Ultimate Gaming Case (£46.99)
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) (£38.76)
Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM (£15.26)
HIS ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail (£187.99)
Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard (£93.99)
OCZ 4GB (2x2GB) PC2-6400C5 800MHz SLI-Ready Edition Low Latency Dual Channel DDR2 (OCZ2N800SR4GK) (£58.74)
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail (£123.36)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) (£14.68)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) (£93.99)
Is it going to be a major problem?
Is there anyway to add to an order?
Just had a thought if it is a real issue i guess iw ill find out and ims sure i can drive to a nearby electroncis store and pick one up, though pc world is poor for components so any recomendations of shops to buy components in the uk? I live near enough slough/reading
The Antec case comes with a 140 top and 120 rear, the HIS puts the hot air out a pci slot.
Why do you need case fans?
theres a rear case fan and the roof fan in the antec 300 which are close to the CPU cooler, whould keep it ice and cool.
Im looking at adding one on the side to keep a decent flow of air for the Gfx Card.
Status
