- 23 Nov 2007
- Midlands
Got this email this morning...
Now that your O2 Broadband Premium package is live, our engineers have been able to test the line speed. Unfortunately, it's not as fast as we hoped it would be when you ordered.
There could be several different reasons for this. Your line may be unable to support the speed due to the distance from the phone exchange, or the quality of the wire, to your house, which, unfortunately, we can't do anything about. However, it could be the way O2 Broadband is set up in your home, which we can help you sort out easily.
Give us a call and we can talk you through some simple steps to try and improve the line speed. The number's 0800 230 0202 free from a landline, or drop the first '0' to call free from an O2 mobile.
But if it turns out there's nothing we can do, we obviously don't want to charge you for a service you can't receive. So we'll switch you to a more suitable broadband package like O2 Broadband Standard. It's free to switch and we'll adjust your monthly bill where necessary.
Best regards
The O2 Broadband Team
I've tried everything i can think of. TCP optimizer, disabling the firewall via telnet, running it on my gaming pc, so i's nothing to do with the cpu or anything like that. The router is plugged directly into the test socket on the master NTE5 box, no extension cables, no other circuits are connected, and only 1 phone is plugged into the micro filter. I've ordered a filtered faceplate, so at least i know i've done everything i can on my side. I am plugged into the master test socket using the original RJ11 cable from the filter to the modem, then a 5 meter ethernet cable to the pc. The house is a victorian house, so the wiring is going to be at least 1930's on the telegraph pole back to the exchange. We had a new line installed from the pole to the house in 1988. It's the multicore type instead of the 2 copper wire type. Is there anything else i can do? What sort of speeds should i expect? I was hoping some of the internet guys on here could help out a bit.
1.7KM from exchange
Uptime: 0 days, 6:33:58
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,295 / 3,503
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 18.5
Line Attenuation (Up/Down) [dB]: 20.0 / 37.0
SN Margin (Up/Down) [dB]: 6.5 / 10.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 23 / 0
Loss of Signal (Local/Remote): 8 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 12 / 0
FEC Errors (Up/Down): 16 / 31,260
CRC Errors (Up/Down): 16 / 37
HEC Errors (Up/Down): 31,741 / 25
Best regards
1.7KM from exchange
