q6600
14 Nov 2006
Newcastle, England
okay i just got my q6600 overclocked to 3.0ghz using 8 x 375
all stock volts, and 1hour stable in prime, keeping prime for going for 4 hours
temps = 52,52,48,48 is this okay?
and if i wana go to 3.2 or 3.4 will i need to increase volts?
or should i stay happy with 3.0ghz
i mean is there a big difference from 3.0 to 3.4ghz on crysis performance etc?
running 2hours now and no fail...
how long is enough to know its stable?
p.s temps dropped to 50,50,45,45
i had heating on in flat :P
one cycle should be enough of small ffts, thats about 5 hours i would guess at that clock... you probably want to run blend for a couple of hours to, to test memery stability
currently doing 3.2ghz as we speak with 9 x 356
my default volt = 1.25, ive had to put it to 1.30 for 3.2
if this is all safe im going to 3.4ghz at 1.4volts and then stop
i would be very happy with 3.4ghz with around 60c load and 1.4v :D
temps now @ 3.2ghz 1hour prime = 49,49,46,45
Don't be scared with voltages, upto 1.5v is fine with the 65nm chips, I've ran 1.55v for benchmarks, but don't run at that speed 24/7. I feel that your temps will be your limiting factor though as every voltage hike is accompanied by a temperature hike. Again very nice VID on that chip.
this has happened twice in 3hours trying to test prime while at 3.2ghz @ 1.3volts
do i need more volt? or just normal crash?
When people judge their CPU voltage, do you judge it on what CPU-Z says is the core voltage, or what is set in the bios, because im noticing a very large difference between these two figures. I.E. Ive set my BIOS to 1.4325v but CPU-Z states CPU Core is 1.31v, and VCORE is 1.44v (dont know the difference is) but this has always been above what ive set in the BIOS.
i judge it via bios
woke this morning and comp blue screened while priming 3.4ghz [378 x 9] on 1.325volts
volt is now at 1.4750 and trying 3.4ghz :(
come on stable plox!
People will normally say, BIOS or load for example.. Quadcore database is all load vcore in windows..
Sounds like you have a vdrop / vdroop issues a lot of boards have options to help with this, what board are you using?
cpu-z is pretty accurate for windows cpu voltages. I've got about 0.05v of vdrop on my motherboard for example 1.45v in bios is 1.4v actual at idle, and perhaps falls to 1.38 under full load. Don't worry about the bios value, the windows value is proabably closer to "actual" voltage the cpu is recieving.
Its an Abit IP35 Pro motherboard. Im just confused with CPU Core voltage and VCORE (both in SpeedFan)? CPU-Z reads the same voltage as SpeedFan for CPU Core, but then SpeedFan has VCORE which is completely different, and hasnt always increased as ive increased the volts in BIOS. Heres what ive been getting:
FSB | Multi | CPU | DRAM Speed | RAM Frquency | CPU Core V | DDR2 V | CPU Core | VCORE
340 9 3060 1.2 408 1.3025 1.8 1.24 1.39
350 9 3150 1.2 420 1.3025 1.8 1.24 1.43
360 9 3240 1 360 1.3325 1.8 1.27 1.34
370 9 3330 1 370 1.3825 1.8 1.31 1.42
380 9 3420 1 380 1.4325 1.8 1.35 1.45
Sorry its not very clear, but should give an indication as to what i mean. VCORE doesnt seem consistent with the BIOS settings what so ever, hence my huge confusion, especially as its VCORE that people are refering to.
Anyone able to clear things up for me?
currently got 3.4ghz [1.5volts in bios and 1.488 on cpuz] going on prime with temps between 59-64 max load
is this okay? im only using my arctic pro cooler 7 at the mo since tunic wont fit on my p31 board, upgrading board next week
