q6600
grrrr, i woke up this morning and prime was still blending at 3.6ghz 1.3volts all sweet!
but then i started doing other things before switching prime off and my comp screen froze, now when i boot it up, nothing comes on the monitor
theres power and everything to the board etc
but 2 issues i noticed, the back of my 4870 theres 2 red lights constant lit up and the fans sometimes starts at 100% on the card and the keyboard dosent boot the num lock button
what have i killed?
currently at work now :(
.s i left the cmos battery out of the mobo for 30mins to reset cmos and that didnt help either fix it either
Check all your components are properly seated and the relevant power leads firmly connected!
D1601 - Red LED On, shows critical temperature fault
D1602 - Red LED On, shows External power connector A was removed
D1603 - Red LED On, shows External power connector B was removed
D601 - Red LED On, shows critical Core power fault
OC have offered me a RMA for my graphics card, but i need another card to check 100% its that card before doing so, should know by 2moro
Sorry to hear this, hope all works out nice and easily!
Edit: With my graphics card (4870) i had to use 2 of the 6 pin pci-e power inputs for it to work, otherwise it complained about not having enough power. How many are you using? Can your PSU cope?
thats my problem
im at work now till 10.00pm, but my friend is bringing his 8800 GTS 640mb tonite at 10.15pm, if this works hes gona borrow me it for 2 weeks
while i get my card replaced :D woot
reverted back to 3.2ghz since temps were rising nearer 70 when fire and heating was on
now im back to 3.2ghz [1.3volts in cpuz] and temps stay under 50c always
much better this way :D
but how can i fix memory? would those timings make me error on prime while blending @ 3.4ghz?
Is this your current oc :)?
