any ati 2xxx, 3xxx or 4xxx series card that comes with ati's own DVI-> HDMI adaptor provided you dont already have one ,otherwise just get any 2, 3,4, series ati card
the ati cards do carry sound and video over the HDMI cable, if you have a DVI -> HDMI adaptor made by ATI.
no, the graphic card as onboard sound.. the adapter is about 2-3inchAaaaah! Pretty neat. How does it work, do you need to buy another cable to run from the sound card to the adapter? Anyone know how big the adapter is? Or even better, have a picture of one!
yes all the 2,3 and 4 series cardsAll the graphics 2,3 and 4 series cards have onboard sound as well? I'm confused.![]()
what are u on??You do realise this doesnt give you any sound right
yes..Well, I never expected that. Some of the 2 series go for around £30-£40 as well. Do they include sound as well? Oh, and thanks for the picture! You're a star.
yes..
what are u on??
this does give u sound + picture on all ati 2,3 and 4 series cards because it made by ati.
the extra pins or un used pins by the dvi are sound on all ati 2,3 and 4 series. so ati's DVI -> HDMI adaptor uses them pinsHow can you get sound over dvi?
There isn't any sound on the cable thats the main difference between dvi and hdmi,
