MM H2g0 is a compact case that can accept 2x 120.2 and 2x 120.1 Thermochill PA rads.
Also accomodates large PSU's, full ATX mobo's and with something like the icy dock yuou can see in the picture 3x hdd's too.
Dimensions are:
43cm x 32.5cm x 34.5cm
gt
P.S: I use a 24" screen so you can see how compact the case is.
If I sat down and tried to design the ultimate dust gathering case this would be it ! just look at all those places for dust to get in and or build up
It was bought off another forum member 'clone' on the members market.Is that a special order, gt?
Could not find one with the big window on top.
Regarding disks, I only need to able to use 2 for RAID 0. Is this possible or you need to buy something extra?
He had it cut to look like this and then had it coloured too.
I run the icy dock you can see in the picture. Can accomodate 3 drives and still leaves space for my dvd writer.
After that there's plenty of room for a couple of 1201 rads in the lower chamber. You could then run two pumps with attached res' in the lower zone and run tubing to the upper zone for the 2x 120.2 rads.
Of course if you choose to have less watercooling in place there'll be a touch more room available.
gt
