e6600 @ 3.6??
29 May 2007
Sunderland/Worcestershire
Hi all,
I've been running my e6600 @ 3.2 for the last year or so with no problems, my recent purchase of crysis warhead, however, has made me consider pushing it to 3.6. I have my fsb @ 400mhz and ram multiplier at 2, and obviously the cpu multiplier is currently at 8, so I'm trying just changing that to 9. I have ran prime and 1 thread fails pretty quickly, although not the same one each time! leaving it running with just one thread and the highest temp I have seen is around 63 degrees. Is it safe to now up the voltage of the CPU a but and see if I can run prime for longer? If so, how far is it safe to go with a e6600. Although my computer has been overclocked for a while now, and I understand the basics, I'm still a bit of a noob when it comes to raising voltages etc.
Any one give me a clue?
Cheers
alright, just upped the voltage a fair bit to 1.4875, been running prime for about 30 minutes and max temp is 68 degrees, is this too hot?? anyone got any advice on what temp I should stop the test?
I tried this morning for 10 minutes or so before my cpu gave up and I was getting around 10fps more. It's just as 3.2 is the minimum requirement for vista and I don't like the idea I'm running at the minimum requirements!
Just tried lowering the volts but I'm back up to 1.4875 now, gunna leave it for a couple of hours and hopefully it should be stable. I've turned me case fans up a bit aswell so the temps have dropped a couple of degrees. Is there a limit on voltages I shj]ould stick to or are temps a good enough sign of when to stop?
That's a 3.2ghz single core pentium 4, a 2.2ghz dual core is minimum for vista. I'm crysis with a 3.2ghz e6420 and it's running great.
ahh,thats good then! Although if this prime stays stable then I'll leave it up at 3.6 anyway (its not summer anymore, gotta take advantage of those low ambient temps!)
