Crysis Warhead: end cut scene issue?
i agree the MOAC doesn't do much damage for each shot, but its rate of fire more than makes up for that, i also agree its a bit tricky since all you see is a stream of ice shards :eek: found it best to use in short bursts, so it doesn't overheat
The pax was an awesome weapon. Look down the sight, stick red dot on target, compensate for movement and then BLAMMO!
beat the hell out of the crappy TAC launcher which was 'thump........not so loud bang' and that was it, its meant to launch nukes FFS!!! :confused:
Personally, I was really gutted at how easy that end monster was to kill in Warhead! I found it harder to get out of the plane wreck with the plasma gun and get to the end monster.........then just drove my jeep into the aircraft hangar and ducked about in there.
When you meet Prophet on the carrier he asks for more power to be diverted to his suits thrusters. Prophet must have seen the inside of the ship, probably more than Nomad too, judging by his reaction. Although Nomad had a completely expressionless Ben Affleck tone about it all.
I guess that's bad news if they do a Prophet story for you guys that hated the floaty level.
:eek: the MOAC was immense, infinite ammo and ridiculous rate of fire! yeah the PAX fires a plasma bolt that im assuming looses containment after a set distance, unless it hits something on the way. using the PAX i felt true power, plus it makes a sweet noise when it shoots and everything it touches explodes!
Where is the PAX? It's supposed to be in the crashed aircraft but i can't find it.
i don't think prophet went into the ship, or else why was nomads nanosuit the only one with information on the inside enviroment, etc. (hence why it was so important he got back to carrier alive) but prophet definately knew something the others didn't! i like nomad to be honest, he lived his namesake and i for one would like to play as nomad in crysis II, but hope crytek give him a bit more depth. also loved the inside of the alien ship myself was very atmospheric and i don't for a second understand all these people moaning about getting lost, managed to get through first time (albeit cloak spamming like mad since i had no idea what anything was capable of!) and i also like the way nomad gives a vocal testamony whilst playing about the conditions of the ship, how freezing it is, etc. very cloverfield-esque in that respect :)
Still can't find the damn PAX. All i can see in the aircraft are boxes which you can pick up but none that can be opened. There are some big boxes but they don't seem to open.
I get killed while i'm in there looking. It's getting kinda boring.
It should have been marked on your map so just follow the big green dot or whatever it was.
The silver box has a keypad on the front and isn't as long as any of the other ones in there.
