How long is a piece of string?
The decking is about a foot above the ground, I was thinking of doing what was mentioned here already. Place some supports underneath the decking to aid with support.
As long as you cut it. If you cut the string at 1 metre, then it will be 1 metre in length, hope this helps.
I am building a raised wooden pond on top of some decking in the garden, it will contain 8 tonnes of water, do you think the decking will hold it?
