and shooting fuel tanks with my silenced mp5 with scope.
Thats a good trick considering theres no mp5 in the game.
Thats a good trick considering theres no mp5 in the game.![]()
The only reason I don't play Delta is because theres no room for strategy or tactics against the aliens and I can see Delta getting old fast on those parts!
just finished it, not too shabby.
probably been answered but theres like thousands replys in here and its late
what best setting with decent framerate for 4850 and this game.
must say from quick go i had its looking a lot better than the first part.
con_restricted = 0
r_WaterGodRays = 1
r_sunshafts = 1
r_colorgrading = 1
r_usePom = 1
r_TexturesStreaming = 0
Make sure you run DX9 mode (far faster), then you should be able to play all Gamer (high) no fuss, then just make a quick system.cfg file enabling sunshafts, pom, and colorgrading and you'll have a game that looks very much like Enthusiast (V High) without the massive performance drop.
In your system.cfg just add in the following:
Sorted![]()
Sorted![]()
Unfortunately I don't know the variable for the wicked looking explosions and particle effects - I'm thinking it's just down to particle effects being set to 4 as a whole in the particles cvar, which is a bit of a bummer as you may as well set it all to enthusiast in the first place, being as it has a big performance knock.e_water_ocean_fft = 1
now i'm at a stage where there's a big airfield, just went up a watchtower and 'used' the radio/computer, looks like it's about to kick off
is this the last 'level'?
cool
damn gf goes to bed at half ten, so i can't play then
cool
Delta is much harder on Warhead with the new set peices.. The train bit is pretty bloomin hard! I mean how many helicopters do the KPA have on that island?!
