If i have power issues, how will they manifest?
26 Dec 2005
Paisley
Recieved my Leadtek GT280 today, ive only got a 550w antec power supply, so im a bit concerned it wont be man enough for the job.
How would these manifest if it dosent work?
At a guess, random shut downs when gaming, either by the game shutting down or the PC.
What are your other system specs as that would give a better clue.
your system wont post :eek:
should be ok, i reckon, shall we put some bets on it :p
make a poll in here with the following
will not boot
will boot but cause problems
boom
will work fine
Well for one you will find yourself becoming agitated and aggressive in the face of superiors....
Take that PSU calculator with a pinch of salt.
A couple of months ago i calculated my PC power usage using it and it stated i'd use 600+ watts. Actual usage was more like 350w @ full load. :D
In fact a media machine i just made was stated as using 155 watts but in the end it turns out it uses only 80 watts at full tilt.
There's a safe margin of error and then there's just plain innacurate. :D
You should be fine if the psu's 12v rail is strong enough for it! :)
gt
