Just received my Datel tool battery so I'll be on CFW soon
I thought I may as well read the instructions that came with the battery to get any idea of how long I should be charging it for.
It says to plug the PSP into AC power with no battery, then insert the Tool battery to charge it - 1 hour minimum.
Is this the only way to charge the battery properly or can it be charged with the PSP off?
Thanks,
Craig.
Thanks,
Craig.
