Antec Trupower 650 enough for this?
Currently on E2180 and a Radeon 4850, with 1 optical and 2 hard drives, but would it be enough if I upgraded to a Q6600?
the TP3-650 lacks the modular cables but it is powerful and is certified to run most dual graphics cards setups. Unless you plan to run two 8800 GTXs in SLI then it will not work lol but for you it is all good
i got the exact same psu and i run 1 x 4870, 2 x hdd, 6 x fans, 1 dvd
and i just blown either psu, mobo or g card :( waiting to see which 1
It seems the Antec Trupower 650 is crap its also price the same with the Zalman ZM600-HP Heatpipe.I'll pick the zalman everytime.If your Antec Trupower is a couple yrs. old or already out of warranty it would be best if you peek inside the psu and look for bulging caps as this is common for psu also caps can fail without showing visual indication so its best to just recap it.
TruePower Trio is Seasonic made and doesn't use Fuhjyyu time bombs.
While that Zalman is made by FSP whose "high end" hasn't been really convincing.
(most Epsilon based PSUs have high ripple, for reason or another those Zalmans haven't shown that behaviour)
Zalman is based on FSP design with improvement from zalman and according to this review this PSU has a very minimal ripple much better than the FSP.I bet its much better than the TruePower just read the review.
Zalman ZM600 Review Click here
Hi fobose i tried to check on how to contact you by pm but it seems i have trouble doing
that.Anyway according to the faq Thug should not have an Avatar but i dont have an avatar its just text.Pls enlighten me on this one as i'm new on this forum thanks.
