Was checking the oil in the other halfs 106, and there was a 'bit' on the dipstick. I wiped it and dipped it again a few times, then out came another bit. Only found the two, after about 2 mins of dipstick dunking. Apart from the large bits the oil was normal, definatley no other contamination.
They were hard, about 0.7mm sq, felt a bit like really hard rubber. Question is, where is it from, and should I be immorally selling the car asap?
It was last serviced in Jan about 5000K ago ( she only goes to college in it really). Car is the 1.1 from 1998, with 75k. I imagine its from some kind of seal? If so, would some kind of engine additive to re-juvinate the seals be worth a shot? Normally I wouldnt bother, but if it will ensure the car last another year or too Ill give it a go
