Best barbs for watercooling loop??
7/16 provide a much tighter fit. I had to heat the ends up in boiling water to get them on.
you wuss, i just rammed em on there :) (oww err)
But using hot water is a good way to help get them on the barb. But as the man says a MUCH tighter fit.
Was wondering whether 7/16" tubing is easier to bend and fit in a case than 1/2", or doesn't it matter much either way?
